It's me again. I'm getting ready for the spring fishing season and took took my 50 hp force out to check it on the lake. When I went to throttle up, it seemed to do just fine, but never seemed to plane out and run as fast as sit should (no top end). Nothing has really changed from before. Starts good, runs okay at idle, but again, won't push the boat as fast as it should. I pulled the sspark plugs and the bottom one seems to be oil fouled, but cleaned up pretty easy. Top plug is in A-1 condition. Is this ignition in bottom cylinder, or carb adjustment? Compression when I bought it last fall was 150 in both cylinders. I bought the motor as a 1988, but it may be 1989 instead. Help, please?
