nightimefishn
Thread starter- Joined
- Jul 27, 2009
- 54
Hi I am having some issues with wiring my new carling illuminated switches.
I have 6 gauge wire directly from battery pos and neg.
I have wired red 14 gauge from blue sea systems fuse panel positive to the middle terminal on the carling rocker. I have black 14 gauge from ground on the blue sea systems fuse panel to the ground on the carling switch.
These are simple on / off 3 prong illuminated switches.
Here is my issue
I have 12 volts to the fuse panel tested with meter. Once I flip the switch I lose power to the fuse panel. And the switch does not light up.
My wiring is planned as follows top connection ground to fuse panel 12 volt source. Middle terminal from fuse panel and bottom terminal to the pos on the device I want power to then ground the neg terminal on the device to a ground buss. It works as discussed when connected in my garage directly to a battery without the fuse panel. I am kind of stumped here and could use someone advice. I always find my help on this forum!!!
Attached a couple of pictures of fuse panel and switches.
Thank you very much!
Here is my issue
