Please Help ME
rrott23
I have a 85 HP chryler out board motor and noticed oil dripping from prop so I tried to add some gear lube I could hear the air being pushed out the prop, So I took the prop off and noticed 2 screws in the inside of prop shered. I replaced them and tried to put more gear lube in and it ran out just as fast as I put it in..Any Help PLEASE
eurolarva
Re: Please Help ME
The lube is coming out near the prop? I think you are referring to the two screws that hold the bearing carrier on near the prop. There may be two empty holes there to connect a harmonic balancer to remove the carrier. Is this where it is leaking? Can you take a digital pic of this? Do you live in an area where it gets below freezing in the winter and if so did you drain the lower unit in the fall?
