i have a 89 force 150 ob 2 problems first, was out boat and it was running fine then out of nowhere it started to bog down idled fine and reved up fine in neutral but only went slow in gear couldnt get it to throtol up shut it down for a bit then worked fine for about 5 min thenm did it again. second problem is sometimes it wont start you turn the key and nothing but then i pulled it over and started it and then starter worked after that. please someone help me.
