please help me out
eddthejailer
hello e-1 and ty in advance for your help in this matter for this is my first post in here but surely not my last.ok now to the details.i have an old evinrude 3hp engin that my dad left me when he died 4 years ago.it is an evinrude model#3302s and serial #b 8122 internet says made in 1963.i havent even messed with the engin til this last week when a friend of mine bought a small 12 foot v bottom with 2 old motors and we started working on them getting them to the water.so i pull out this old thing and we mount it on the saw horse in a bucket of water.it started right up.first thing i noticed was it said to mix 1/3 pint of sae 30 outboard motor oil to 1 gallon of gas.i assumed that since 2 cycle oil is availible now i should use that since i couldnt find outboard motor oil anywhere in sae 30 weight.after olny 30 minutes on the water it lost power but remained running well just without the get up and go.plugs look fine and motor wasnt hot???what happened??also i need any info you can give me on what mix i should use,how wide to set the spark plug gap.how to check the lower unit gear oil?haw to winterize it?how to tune it up?just about anything you can tell me would be knoledge to me.also there is a round knob in the senter under the throttle bar and beside the choke.it is very hard to turn i even had to use a pair of plyers to get it to move.since my faher is dead and he didnt have much to leave me i would like to keep this motor up and going since my most fond memories of me and my father are either on the water or fishing from shore.also if you know any dealers in used or new parts for this engin please let me know that also.ty so very much for your help....in loving memory of my father john(catfish)threlkeld from covington ky.
Xcusme
Re: please help me out
Ed, Welcome to the forum. :D <br />Yes, you're motor is a 1963 model. Since you're new to outboard motor's, I suggest you buy a service manual for your motor. There is a link at the bottom of this page to buy one. The small knob you mention is the low speed idle mixture adjustment screw. If you remove the motor cover, follow the shaft of the screw. You'll see that there may be a 'packing nut' that the shaft goes through at the carb. If you slightly loosen this packing nut, the shaft will turn easier. Don't loosen the nut too much or it may start to leak. If the motor hasn't been run for 4 years the carb will probably need rebuilding as it is probably fouled with varnish deposits. A carb rebuild kit will have all the parts you need to rebuild the carb. <br />You should replace the water pump impeller, this impeller pumps water to cool the motor. Replace it even if you may think it's OK. Never run the motor out of water, it will overheat and damage the motor. The water pump impeller and carb kits can be ordered from Nappa auto parts, or from an Evinrude dealer, just have the year,HP, and model info ready when you order.<br /><br />You're motor uses 5.3 oz's of oil for each gallon of gas. Use regular 87 octane gas.<br />This gas to oil ratio is 24:1. This means 24 parts gas to 1 part oil. You can use Marine outboard oil -TCW3 only.<br /><br />The service manual is an essential item to have. It will explain repair , tune-up, and maintenance of your motor and is money well spent.
Joe Reeves
Ed..... Use Champion J6C spark plugs, gap set at .030 . The points set to .020 on the high portion of the cam lobe. As Excuseme states, the mixture is 24/1 (1qt of 50/1 oil to 6gal gas). A octane rating of 87 will be fine.<br /><br />You'll see two large slotted screws in the lower unit, a drain screw and the oil level screw. Fill the lower unit from the bottom hole until it flows out the top hole. Use what is called "HiVis" (80/90w) oil which is available at Wal*Mart, K-Mart etc at a reasonable price. It is also available of course at your local dealership but at a higher price.<br /><br />The loss of power could be anything, loss of spark, overheating, fouled carb, blown head gasket etc. Check the compression which should be in the 70 psi range and even on both cylinders.<br /><br />With the s/plugs out, rig up some kind of spark tester and set the gap to 1/4". The spark should jump that gap with a strong blue lightning like flame.<br /><br />A engine sitting for that length of time will no doubt need a new water pump assy, and also the carb should be removed, cleaned, and rebuilt with a new complete carb kit. Outboard carbs tend to foul, clog, gum up when sitting.<br /><br />There is a fuel filter screwed into the fuel tank. It would be a good idea to check that to make sure it's not fouled.<br /><br />The knob you speak of is the slow speed (idle)adjustment needle valve knob. As Excusme stated, the packing nut should be adjusted so that the knob will not turn with engine viberation, but so you could turn it if needed.<br /><br />The high speed jet is a fixed brass jet that is located in the center bottom portion of the float chamber. This jet must be absolutely clean.<br /><br />The proper adjustment for the carburetor s/speed needle valve is as follows:<br /><br />(Carburetor Adjustment - Single S/S Adjustable Needle Valve)<br />(J. Reeves)<br /><br />Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.<br /><br />Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.<br /> <br />Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.<br /><br />A word of advice.... When entering a long post, break it up into paragraphs so that it makes for easy reading for us old timers. One long post in a single paragraph tends to flow together and information has a way of getting ignored.
