Please help me ID this engine on my boat : ) Pics inside.
blue_77
Hello all,
I feel like a bad parent who forgot what day his kid was borne. But I my defense this is my first boat and I am eager to learn all the info I can. For one I just really need to Id the engine. Here is what I do know.
Outdrive is a Volvo Penta. This combo is on a 1985 Sea Ray Seville. Engine is 8 cyl and has no real name plate or any noticeable tags I just found a couple of numbers on it. Please help with correct ID. Also the spark plugs are Autolite 23 dunno if this helps. Thank you all.
twincam1971
Re: Please help me ID this engine on my boat : ) Pics inside.
ford 302 or 351. Definitly Ford though
twincam1971
Has a Malory ignition too. Nice. Distributor looks Malory, Coil is accell
twincam1971
If u can tell me the firing order I can tell you what it is. Firing order should be stamped on intake
Handegard
It's a Ford 302 or 289, if you pull a valve cover, it will have either 302 or 289 stamped in the head somewhere...
The C8 casting number on the intake means it's designed in '68...
