please help! Johnson outboard 20HP overheated and does not start anymore?
bigflopz
outboard overheated theres still spark and its not seized any ideas? gas is clean also
peehole was clogged i unclogged it
bigflopz
but iknow thats not the best way but as i said i was working great before it over heated
oldboat1
May get back on the water with a new head gasket, torqued to spec. NAPA can probably provide/order a gasket, and perhaps lend a compression tester.
bigflopz
so my friend tested them and said there around 115 110 1 and 2 so is that not bad?
oldboat1
That should work. Resurface the head, and put on a new gasket. Have your bud retest after reassembly.
bigflopz
[No message]
bigflopz
Yeah the compression was low so I pulled the head gonna replace the head gasket today and clean the cylinders
