FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
My number 2 plug no spark could this be a coil problem or something else plugs where replaced 2 weeks ago and motor has not been run in five years any ideas
Re: please help 1976 evinrude 35hp won't start #2 plug has no spark
Swap coil top to bottom and see if the problem follows. Crazy Low Tension Ignition system in that one. Two Points and Condensers, one exciter coil under the flywheel. Might have a problem with one set of points not opening.
Jim
Trim 1/4 inch off each end of the spark plug wire,Have you taken the flywheel off to check the points? Make sure the points are set to .20 on the set spot on the timing cam.You may even use a points file on the points to clean them up.
