Thrawn5499
- Jun 27, 2017
- 34
So today i purchased a 1975 mercury 200 20hp. Motor started right up and seemed to be in good running condition. I brought it home and that is when the problem started. Some how, not sure how it happened too fast when i set the motor on a stand and started to turn away, it fell onto the concrete. It fell straight down, landing on the prob. Luckily it doesn’t look like it suffered much damage. The shift lever is broken, the prop cap is broken, and the prop shaft is bent. The prop itself doesn’t look damaged. But there is no way to use the prop end cap with this prop. Not sure if the end cap needs to be on or not. The main issue is the bent shaft. I am having a hard time finding one, and the instructions on how to replace it. Can anyone help? Thanks
