mattkenton
Thread starter- Joined
- Nov 4, 2008
- 106
I'm in the process of rebuilding a trailer that has a TON of surface rust. The rims and lugs are shot, so I need to remove them before sand blasting the trailer. I have a couple questions. If i remove this star nut that holds in the bearing, will this also release the hub from the axle for me? Additionally, it looks like the lugs have rotted away on the back side of the hub. I see no posts that are keeping them from slipping through to the rim face (SCARY!!). Or they might screw directly into the hub. How should one go about removing lugs and nuts that are about 75% rusted through?
Here are the photos.
