Scanman1973
Thread starter- Joined
- Jun 26, 2011
- 22
Hi All,
This past season I had to replace the bushings and seals between the steering fork and the control arm on my DP-E outdrive. I just had the boat pulled for the winter and when I took the outdrive off to bring inside (don't know why I did really) there is play in the steering forks. I remember putting the forks back in the transom shield, it was really tight, I don't know why there is play in it now. It is a jack shaft setup, so I have access to the back of the drive when I remove my livewell. Is this OK, and if so how much play is OK?
Thank you,
Andy
Thank you,
Andy
