Plastic wood?? has anyone tried this stuff...
ToyBoat5X
Hi everyone,
As you may or may not know, I'm in the process of rebulding my boat. Well I've been looking for alternatives for wood and came across this site http://epsplasticlumber.com/lumberpricing.shtml Has anyone tried this?
I bought a 4X8 (3/4") Coosa Composite board for my transom but that stuff is way too expensive for the deck and stringers. I thought "plastic" would be the best way to go.
I'm using epoxy and biaxial cloth to to the boat. I have figured that the epoxy won't bond to the Plastic well but when I removed the old stringers it left a good 1" lip so that the new board can slide into. So what I am going to do is place the plastic stringers in that groove and cover the top and around with biaxial and epoxy so that it is structurally sound. They also sell plastic plywood sheets, I was thinking of using 1/2".
Any comments...
Thanks,
Andy
tommays
Re: Plastic wood?? has anyone tried this stuff...
I have played with plastic lumber on decks and its not even close to the strength of standard lumber
Tommays
ToyBoat5X
Tommays
I was also thinking about just replacing the stringers with plastic and use marine plywood for the deck.
Im assuming this would give it a lot more strength.
Are there any other downsides of using all plastic?
Andy
tashasdaddy
i think your a throwing good gas money away.
Paul Moir
http://epsplasticlumber.com/astm.shtml
The modulus of elasticity of douglas fir is 2.5x that of the plastic lumber. That means the plastic will make a much more flexy structural. IE it's far weaker for the same thickness than wood.
Talking purely theoretically here, the only stringer subsitutes I think I would consider would be formed fiberglass or aluminium.
Bob_VT
"Talking purely theoretically here, the only stringer subsitutes I think I would consider would be formed fiberglass or aluminium."
Paul Moir
DITTO. and I am partial to aluminum myself.
Ayuh,..............
I Wonder what happen with that Fella that was going to build Steel Box Tubing Stringers,..??..??........
I find that Plastic Lumber to be Junk in a Boat..........
stevieray
And it's at least 2x the weight as well.
ToyBoat5X
Yeah...
Im just gonna stick with good ol' wood
Thanks guys.
Andy
dhatcher
lol thats one thing you got to love about this forum, they will tell you how it is
