Before I set my stringers I would like to know if I could place my deck on top of the existing fiberglass shelf which is around the perimeter of the boat. The original decking was 1/2" plywood, therefore I would like to place 8" rips under the fiberglass lip at 1' intervalls starting from the bow and working my way towards the transom securing with stainless screws filling in between with 1/2' rigid styro than decking on top of that with 5/8" exterior ply and glass as per normal procedures. Transom---Do I set my new transom in a bed of pl adhesive or does it set in a bed of resin? When I removed it there was about 3/4" of resin between the hull and bottom of transom. In the pix if you look at the transom both sides have a fiberglass edge(light blue) which the transom set in. Now that the transom is removed can I leave those two wings in place slip the new transom between them and fiberglass over them again according to procedure or do they have to come out along with those two areas filled with foam which I do not know what they are called
Ps : Interior of side of transom was not glassed just painted.
Peace Out
Plaz
Peace Out
Plaz
