Re: Pitted Aluminum boat
Ayuh,...
I had somewhat of an Issue like that with my tin Starcraft a few years ago, when I mistakenly ran a Ground Path thru the hull, instead of wires...
I just sanded as normal,+ used the Rustolium brand of Aluminum primer,+ now touch it up with the regular Rustolium enamal....
If you've got Pitting on the Inside of the boat,... Use Gluv-it...
