I?m reassembling my V4 140h 1978 Evinrude. I installed the pistons and crankshaft but the shaft would not do a full revolution. I temp installed the shaft bearings and the crank cover (to center the shaft) and it still will not do a full turn. I noticed that the 2 port side pistons bottom out and that is not allowing the rods to over-center (both directions) and the crankshaft can?t make it around. This was a running motor that busted a piston ring and that?s why I?m rebuilding. The skirt in 3 of the pistons were cracked, so I imagine they were hitting before. The motor has been worked on before I got it.
What can be the problem?
