racemonster
Thread starter- Joined
- Aug 18, 2008
- 5
Complete newbie here!
Purchased this used boat on Friday and had it out on Sunday and evrything went well.
I have a couple of questions now that I am more familiar with the boat.
1990 SmokerCraft 17ft, 1991 Johnson Tracker 115HP Oil injected.
When I turn the key on I hear a loud ping from the control box?
Is this a normal indicator for something?
It will also make the same pinging noise at random it did it more in the first half hour and and tappered off to where it was not doing it any more,
but it always does it when I turn on the key.
I also need to know what kind of oil to run in the oil injecton tank?
Would this motor charge the battery or do I need to charge it before using the boat?
Are there any guidelines as to what position the tilt and trim should be set to?
Thanks in advance!
Rob
Thanks in advance!
Rob
