Picked up my free boat
fishrdan
Re: Picked up my free boat
Cool free boat!
I notice you mention that the boat has shifting problems and that the throttle cable was replaced. Check to make sure the cables are adjusted properly, it's kind of tricky so follow the manual.
The trim tab (zinc anode) and bolt off the outdrive is missing, big hole above the prop.
For oil I use Shell Rotella 15W40 (25W40 if I can find it) in my Mercruiser 3.0, available at WalMart for $10/gallon
myoung84
This may not be the right spot to post but, I tried starting it today after putting in a fresh battery and gas and tried to crank it with no luck. There is no spark and no fuel pumping.
