Perpetual 120v will this work???
1Baker1
OK, so my pea-brain is on overtime,
Somebody kindly shoot me down or build me up on this idea.
Quite simply, take a generator, rip off the gas motor, replace it w/ a 12v,
use a deep cycle battery to power up. Now comes the fun part, plug
in a charger to one of the outlets, connect to battery, for constant or intermitant
charging, use other outlets for the boat.
Am I genius or idiot ?
Thanks for any input,
Jack
Silvertip
Honorary Supreme Mariner
Re: Perpetual 120v will this work???
Do you really think nobody else has thought of this? If it worked we would all be using electric cars decades ago.
1) It takes a given amount of current (amps) at 12 volts DC to run the motor.
2) It takes a given amount of power (as in horsepower) to run a generator producing XX amount of current (amps/watts) at 120 volts.
As an example, a 2200 watt generator will typically have a 5 HP gas engine on it.
3) When is the last time you saw a 5 HP, 12 volt DC motor that would run more than five minutes on a 12 volt battery?
4) Using your logic, you could plug a charger into the generator to charge the battery as well. (Also a failure in practice!)
5) Perpetual motion has not yet been invented - so the answer to your question is NO! Not a chance in H### that would work (at least for more than 5 minutes).
Motors are less than 100% efficient so you get less out of them than you put in.
Power transfer (motor to generator) is also subject to losses depending on the coupling.
Generators output less than the power put into them - again less than 100% efficient.
Battery chargers are less than 100% efficient.
Inverters are less than 100% efficient.
Lesson: Any conversion process requires more power INPUT than you can get OUT so you lose ground quickly.
Jack
Ayuh,... In this case anyways....
