Perko switch
Teknotchr
I am wiring a dual battery Perko switch to run the accessories in my boat. My question is in order for me to hook the existing positive wires to the common terminal of the Perko switch I will need to cut off the existing top post terminal from my current boat wiring and replace it with a flat terminal. Is this correct? It appears to me that this is the only way to connect my boat wiring to the common terminal. Thanks!
TSL812
Re: Perko switch
You can do that or you can un-hook it from the starter and use it to connect the battery to the switch. You can buy one with ring terminals on both ends to connect the starter to the switch.
Teknotchr
Re: Perko switch
Thanks! Wanted to be sure of my options before cutting the terminal off and creating extra work.
