Removed foam early in the morning. Filled up boat with water, about 8 inches. Right away found 3 leaking rivets up front, 4 rivets down the middle, 1 hole in the center lower part of boat. Also found water coming out of Livewell port next to the boat drain. The last leak I found was pissing through the transom. Transom leak was right at the center, couldn't see the hole because the engine tilt and trim bracket was covering it. Right now I feel like not continuing with the project. I will have to lift the boat off the trailer to fix leaking rivets, get the crack welded and remove the engine to inspect the transom. Roughly how much time and $$$ will I need to continue. Pls help experts. See pics.
