Performance spark plug leads for older johnson 35hp?
brandonsmith5150
Hello everyone, I just signed up today specifically for this initial question. I've found a lot of answers in the past by looking at previous threads here but have found nothing regarding spark plug leads for older smaller outboards. I've got a 1984 Johnson 35 hp 2 cylinder I'm wanting to tune up before warm weather hits full time. My dad and I fish crappie tournaments a lot and sometimes troll from 1 to 3 mph for hours at a time. I work out of my vehicle for a living and understand how important good spark plug lead wires can be in that setting, I can only assume good or perhaps 'performance' leads for my outboard would be important as well. Thanks in advance
nwcove
genuine OEM replacement wires are as good as it gets. dont go out and buy automotive type wire!
Honorary Supreme Mariner
There is no need for any fancy plug wires.----Just metal core factory ones give you the performance you need.----You can not believe all the claims you read about !!
boobie
As said above, stick with the OEM wires and you won't go wrong.
gm280
Actually OEM wire core wires are as good a performance spark plug wires as you can get for any OB engine. Just make sure both ends are good clean non-corroded connections and you will have the best you can buy. But equally make sure everything in the entire ignition system is good and clean as well. Any ignition system is only as good as the weakest connection... Now where have I heard that before... :noidea:
