Performance Parts
gregmercer
What kind of work can I do to my Volvo Penta 230 4 Banger to get a little more power out of it. An extra 10 hp would be awesome! <br /><br />Anyone done any of this work before?<br /><br />Greg
gregmercer
Re: Performance Parts
Sorry about the double post, could one of the moderators please delete one? Thanks
dodge1971340
Hi greg!! What year is it? And what kind of $$ do you want to spend :eek: They Prob don't make to many marine hi proformance parts for a four banner. Just the bummbel bee four bannger cars on the road today. but you can do basic machine work to the heads to prob get that kind of hp you want, but to tell you the truth you prob won't see it in the speed or onplane time with 10 hp gain. ;) .... Good luck to ya and God bless!! Dodge
gregmercer
Its a 1993, you don't think I would notice any gains with an additional 10 hp?<br /><br />Greg
Don S
I think the word "awesome" is a bit over the top, you are going to need approximatly 20 HP to gain 1 mph, and hp on a marine engine is expensive. Especially on the Volvo rubber band engines.
tashasdaddy
greg, for the cost, no. Haven't seen any pictures lately in the restoration forum. guy's this 18 year old has done a fantastic job on his boat.
lilmandavis
mile high mariner has been working on a hot 3 liter. it runs like a raped ape way up there i wonder what it would do at sea level with the right jetting?!?
Tail_Gunner
I am under no certain term's 100% sure on the following but i have read enough and have started on my engine to understand that most marine engine's come hot out of the box (factory) as compared to auto's.<br /><br /> They are tuned to run @ high rpm meaning the cam has been altered and the air intake system as well. carb's jet's manifold etc etc etc.<br /><br />It would take a very major modification such as boring,flowing and top end work and after that it would take new gearing to run the stern drive.<br /><br /> I do believe however you can increase preformance by doing hull work,( Teflon racing paint.. :D ) that is making it more efficent. You might want to look into smart tabs increasing your hole shot preformance and from there find a prop that will work the most efficently with your hull.<br /><br />By the way you do do nice work, great job... ;)
paulie0735
Greg, 10hp gained for a boat engine is going to be very hard to notice at the helm. Remember you need to find enough hp to spin a bigger prop at the same rpm as you have now, or spin your current prop faster via a gearing change, to achieve either is going to cost more than its worth to do. If your serious than the only real option is forced induction, a low pressure turbo or A paxton style supercharger would also give you a noticeable increase at 'relatively' low cost and will be a lot easier to live with compared to getting the same hp via conventional methods. Good luck.
Mile-High Mariner
Greg - if you want more speed and faster on-plane time, here's an effective way to achieve both:<br /><br />Remove your motor, drive system and all peripheral accessories, cables, guages, etc. necessary to operation of the power package; place all of the mentioned items into a mid-90's or later Stingray hull of ~18' length, and let the good times roll! :D <br /><br />Everyone's comments are right on - any meaningful gains in output are going to cost you a bunch of shiny pennies, and require careful consideration of what you want to achieve by boring, honing, porting, shaving and otherwise modifying your motor. A balanced, blueprinted engine is nice to have, done correctly and by the right specialist, but the performance upgrade options for our little marine 4-bangers is obscenely limited. Not that you should give up, just be committed to your goal before you try to wring "10 hp" out of your motor. With the kind of green you'll need to dedicate to the effort, I would quadruple your power gain goal, to 40 or more hp. You'll be looking at the mentioned 2+ mph gain, but the real gain is in hole shot and cruise authority. Someone mentioned the need for a gear ratio reduction but, unless you change the operating RPM range or make a major change in your torque curve, this shouldn't be absolutely necessary.<br /><br />BTW - lilmandavis is right - so far one of my project motors really does go like a raped ape. I'm observing its operational range and characteristics and watching to see how it stands up to standard duty cycles in its modified form.
lilmandavis
how do you think that would run down on my level mile high guy? - sea level?
gregmercer
Thanks for everyones input!<br /><br />Greg
