Performance of 75 Johnson with low compression?
Syntax
Have a 75 hp Johnson from 83/84 that showed 7, 7.2 and 7.5 bar (100-108 PSI) in a compression test. From what I've read, these must be around 8-9 bar (120-130 PSI) optimally. I wonder what this engine miss of effeckt wear-wise.
relocyo
Re: Performance of 75 Johnson with low compression?
Older motors have lower compression, I think what is key though, is that all the cylinders are within 10% of each other, I would suspect the motor to run ok-good...
nwcove
its a 30ish year old motor, those comp numbers are looking good . not sure what you meant by the last sentence in your post, but you would barely notice any performance gains from what you have... to what you want.
Syntax
Thanks for great replys. I'll be using this engine afterall.
