freebird63
Thread starter- Joined
- Apr 13, 2008
- 10
I have a 1984 evinrude 70hp on a 1989 truline sportcat fiberglass vee hull, the prop is an aluminum 12 3/4 x 15, it will only run at 28mph per gps at 5000-5200 rpm, ran half a can of seafoam thru it, champion plugs, the motor is mounted on the third hole down on the transom, I thought maybe the motor was setting too low in the water. The guy I bought the boat from replaced the floor and put all new foam under the floor. Its a smooth running boat as far as rough water goes. But I feel this boat should be able to run at least 40mph. Any ideas why it does not pull 40mph????? I am getting discouraged. A boat mechanic suggested putting a SS prop on it. The rpm's are suppose to be 5000 to 6000, wouldn't a bigger SS prop bring down my rpm's???? also the boat guy said that for every hole i moved my motor up I would gain 3mph. Please someone give me some suggestions before I go out and sell this boat.
