pee hole?!?
yoteginosko
i just got a boat and im unsure of the year but its its a FORCE outboard motor, i do know from looking online and what not its between 85-89. i know its an 85hp motor. i have had the boat for about 2 weeks now and finally got it to start, only problem is i cant find the pee hole and i dont want to over heat it. can anyone help me?!?
jimmy120
Re: pee hole?!?
I assume you started it out of the water. Do you have it hooked up to muffs when running it out of the water? The "pee hole" should be obvious if your running water through it.
yoteginosko
Re: pee hole?!?
Yes I put the muffs on it. I have a friend that is a mechanic that came over and helped me get it started once we got it to run we turned it off put the muffs on it and still nothing. So we put it an a bucket that completely submerged the lower part of the motor about a foot above the propeller and still nothing.
jimmy120
Re: pee hole?!?
If it is not peeing then it is not pumping. You may need to replace your water pump. Do not run the motor without the pump working correctly. Here is a video of a 1986 Force running. Look just below the cowl (cover) and you will see a small stream of water coming out of the engine, this is where the most "pee holes" are located.
http://www.youtube.com/watch?v=sdTZahq9chs&feature=related
Check out the stream coming from just below the engine.
goodtimesfishing
Re: pee hole?!?
your motor does not have a actual pee hole, but water should spit out the 2 holes on the very rear(see video above) the stream coming out the side in the video from above is not on force,(that one might have been added) they did not come with a pee hole, water just comes out the exhaust holes. You can add a tell tale(pee hole), do a search on this site and it shows how to do it. It is real easy to add one and I would recommend it. To read more about this just do a search of "force tell tale" or "force pee hole" and you will see all the posts from people trying to find the pee hole that does not exist on force.
roscoe
Re: pee hole?!?
You have no telltale on that motor.
THe one in the video had one added to it, as it says in the title.
BlkY2k
Re: pee hole?!?
I just added one to mine yesterday. Theres a thread at the top of the page to tell you how.
yoteginosko
Re: pee hole?!?
i decided that i was going to replace the water pump because i found out that the guy that had it before me his dad had started it without water or anything so im thinking it burned out the water pump..... how do i get to it? i pulled the 6 bolts off the bottom of gear box and cannot seem to get it loose any ideas?
yoteginosko
Re: pee hole?!?
thank you guys for the help, turns out the propeller in the water pump was bad. but i got her going thank you so much. any ideas on how to remove that flat head bolt on the top of the motor for a telltail? its in there pretty good and i dont want to strip it.
