Re: peanut butter
Here's how I do it...
Peanut Butter
Start by mixing your resin.
Then add Cabosil, Wood Flour, etc... Add small amounts at a time and mix it in. It will be the right consistency when it doesn't run off the stirring stick. It will be similar to Vaseline in texture though not quite as thick.
Super Duper Peanut Butter
I think Oops! gets the credit for naming it that.
Same as peanut butter but add milled glass fibers. Oops! may have his own proprietary blend of secret ingredients.
Don't get sloppy with peanut butter. You do not want to have to sand any off.
Filler / Fairing Compound
Add 3M Glass Bubbles a little at a time and mix it in. The more you add, the easier the cured product will be to sand but it will lose strength. Once you have enough glass bubbles mixed in, then add small amounts of Cabosil until the consistency is where you want it.
Bonus tip...
Before the resin completely cures, you can shave off excess peanut butter with a "surform" tool.
