109jb
- Jul 15, 2008
- 1,590
Re: Passenger car tires on trailer?
IMO, passenger car tires are fine for smaller relatively lightly loaded trailers. Such as single axle under 3000 lb loaded trailer weight. I have used car tires in this application. I will not however use a car tire on a heavier loaded trailer and especially not on a tandem or more axle trailer. For tandem axle trailers, you need the sidewall strength of the trailer tires and the smaller contact patch (less traction). If you don't believe it, come over to my house when I've got my skid steer on the tandem axle trailer and watch me take a tight turn on pavement. A single axle trailer can make a turn without any tire scrubbing. The only side load the single axle trailer tire usually sees is the lateral g-loads from turning at speed, wind side loads, and side load from sway. A properly loaded trailer isn't as prone to sway so throw that one out, and the other 2 the tire sees as much of as when it is installed on a car.
Just my opinion
Just my opinion
