parts house says "cant help it's too old"
zzada
i cannot find these parts locally, for my 1969, 85 hp evinrude model #85993s serial #eo8841. safety switch, points, plug wires, cap, rotor, and reverse cut-off spring. maybe some one can direct me to where i can buy them. thanks :)
alcan
Re: parts house says "cant help it's too old"
Hi Zzada<br />Unless your rotor and cap are broken or tested bad. Clean them up and run them. The same goes for the points. The points in this system are are just a trigger they don't carry a lot of voltage. They don't wear as much as in other systems. The cap and rotor will set you back quite a few bucks. These parts are not desposable like automotive parts. The plug wires screw into the cap. To replace them buy some real wire spark plug wire (bulk). After unscrewing, Carefully pry the crimped screw ends off the old wires and reinstall on the new wires. Call Seaway marine in Seattle wa. Give them your check card # and address and they will send you all the parts you want. These parts are not inexpencive anywhere, so you might as well get them fast, delivered to your door, no headaches.
zzzzz
Seaway Marine=...1-800-332-0803...if not-try Wholesale Marine at 1-661-251-4040 :D
zzada
thanks alcan and zz ;) i did not know that the plug wires unscrewed from the cap. there is something in the screw connector maybe soldier or ?? what do i use to connect the wires?
Terry H
The ends of the wires are just crimped on...you can buy them at NAPA auto...#18-5224, about half a buck each. Or you can buy a spark plug kit for that thing with all the parts for about 20 bucks...just a Thought
12Footer
We can't help you, it's too old....LOL chuckle-chuckle..Couldn't resist. I just wanted to add, try ebay daily. It has been a fantastic source for me on older engines.
ajp
www.outboardrecycle.com<br /><br />Mikes Marine salvage has a bunch of good used parts. I got a complete electricle for my 1969 115hp Johnson.
Lark40
I have no problem at all buying any part I want for my 1960 Evinrude 40 from any old J/E dealer. On the other hand, the parts always cost a small fortune.
nimmor
Another place for you to try is <br />www.tenkillermarine.com I ordered some parts for my 1969 Johnson from them back in the spring so I know they carry the older motor parts.
