Parts for 1967 18hp Evinrude
Phil J F
I have a 1967 18hp Evinrude fastwin model 18702R that I want to buy parts for. In particular, water pump parts and the seals, gaskets and O-rings for the gear case, breaker points and condensors. Unfortunately all of the parts list on the online stores only go back to 1968. I believe the parts listed for the 1968 18hp Evinrude are the same parts as used in the 1967, but I am not sure and I do not want to do any damage by installing parts that are not intended for this motor. I'm sure if I could get a hold of an old timer in the parts department he would be able to set me straight...Any opinions or suggestions?
Sorry , but there is one site that lists part back to 1955. But you are correct in that the 67 parts are the same as 68 model.
TN-25
Changes to the 1968 18 include:
1. a revised smaller fuel pump that helps with vapor lock
2. A more streamlined gear-case with the elimination of the forward protruding "nub" in the "bullet"
Otherwise the 68s are completely the same as the 67s mechanically.
