Painting over epoxy
Will I be alright to use the majic painting procedure over epoxy resin? I want to out fairing compound over the epoxy resin to get is nice and smooth, then Rust-Oleum primer and majic paint.
gm280
As long as the primer is compatible with the top paint. Always try to use the same manufacture of primer and top coat. They will work perfectly with each other then.
