quackaddict1
- May 30, 2008
- 138
Hey guys, a question for you all. I recently picked up a 1974 Grumman sport boat, its in decent shape (I have repaired a few rivets, and need to put a transom in it) but the paint sucks, I have spent most of the last couple days grinding it off with a flap disk on a grinder. Now that I am getting close to paint, what is the best way to go about getting good adhesion to bare aluminum?
What presteps do I need to prep everything after im done grinding? The inside of the hull has no paint, will a regular car wash soap get the scum off of it?
What kind of primer is best for this application? I have had very mixed results with etch primer from a rattle can, will a two part epoxy primer be better? Im not afraid to spend some cash on paint and primer, I just want the stuff to stick.
I am also planning on putting a bedliner kit in the bottom of it, where it will see the most abuse, I have done this on another boat and am very happy with it, I will then paint over that to match.
Any comments you guys have are appreciated.
