painting a 12 ft aluminum seaking
jerry101
got all the sanding,priming,sealing,ready for paint ,the color i'm thinking on using is : gloss royal blue rustoleum oil base paint,,,,,the color i'm hoping on getting if i can mix this white paint with : is a sky blue, the problem i'm having is i cannot get a white rustoleum in gloss,the question i have is : is it possible to mix flat white with this blue , to make it sky blue or close,or do i have to keep looking for gloss white? any help would be appreciated ...thanks
rivermouse
Re: painting a 12 ft aluminum seaking
They make the white in a non flat. It will mix with the blue. I used the blue right from the can on mine and it is holding up well after 3 seasons.
jerry101
this flat is the only white they carry here..
Woodonglass
If they're both oil based it will work fine. Just won't be as glossy. Check the My Flamingo link in my signature below I think you'll like the color of my boat.
