Re: Overweight Robalo
I just got done shoveling up about 600 lbs of that closed cell foam, it came out of a boat that was over 800lbs overweight. The foam degrades and will soak up water over time. See if you can get to an area below the deck and take a core sample of the foam.
I do find it hard to believe it's 1100 lbs of water weight, but I've seen worse.
Has the boat been stored outdoors uncovered much?
What trailer do you have under that boat? The weight you list sounds like a Load Rite 192500 or similar going by the listed weight. That would be a single axle roller trailer. I'd weight the trailer alone if possible to be sure. Take into account things like larger tires, heavier tires, winch weight, tie downs, etc.
It all ads up fast.
I just sold a larger single axle Load Rite roller rated at 2500lbs, it weighed in at just over 730 lbs, and that was only rated for a 19' boat. Your Robalo would take a much heavier trailer. The original brochure listed my single axle Load rite at 575 lbs. as shipped. The 730 weight was even without a winch. It also had no brakes.
My old tandem axle Highlander trailer weighed in at just over 1200 lbs without a winch. That was good for about a 20' boat. This trailer also had no brakes from the factory.
Have you had your boat in the water? How does it sit in the water? That much overweight and your bound to notice a lack of freeboard in that boat.
