overweight boat?
WSUDERMAN
Well, I have a question for all the experts here!!!<br />I got the weight of my boat yesterday! Bad news,<br />Total weight was 8420 <br />Subtract truck (curb weight), passengers, fuel (both boat & truck) and equipment = 3325 lbs.<br /><br /> Documentation from fourwinns says the boat should weigh 2200 lbs. Could a single axle trailer weight 1100 lbs.? Or does my boat need to go on a diet??
Bob_VT
Re: overweight boat?
That's probably the hull weight un-rigged without the motor. Add a motor (outboard or I/O with drive) fuel, controls and it adds up. Do you trust the weighing method? If you ask a DOT person in your area they have drive on scales....use 3 and drive the wheels on two and disconnect the trailer onto the third....or get the boat and traier weight alone on a scale then weigh the empty trailer.<br /><br />Bob
WSUDERMAN
Thanks for the tips...<br /><br />I am not sure if i should be confident in the scale, I went to the local landfill's drive on scale so i have no idea when it was last calibrated.<br /><br />According to 4winns the 2200 lbs boat weight includes all rigging and motor/stern drive.<br /><br />Getting the trailer on the scale without the boat would be tough! I guess i could weigh just the truck and get a bit closer though.<br /><br />What do you think the average weight for a single axle, no brakes, steel, bunk trailer is? Its a Shoreline so i can't exactly call the mfg to get the info and the info sticker on the front left has worn off.
Bob_VT
Why not uncouple the boat/trailer on the scale and do it alone.<br /><br />Bob
sea wolf
i have an 89 eagle bunk trailer, single axle for my 19 ftr. it weighs i think 1000. lbs. so the weight sounds about right for yours. your trailer wt. should be on the state reg. tag.
WSUDERMAN
Bob,<br />There was a very long line at the dump that day, so did not want to be rude but i will call and see when the slow times are and try that! Thanks.<br /><br />Sea Wolf,<br />Thanks, your trailer weight has given me hope! I looked at the state reg, no weight there, but i will try the title!
oldboatsal
I know that I can lift the trailer for my 17 footer. My trailer cant weigh more than 350.
