I have read some post for my answer and had no luck, so here it goes. I have a 1988 120 Johnson m# J120TLCCA. I bought it on a boat for just the motor and it run good with good compression when I tried it out. I swapped motors and found the buzzer on the boat I took it off had a wire cut so it would not sound off. Now on my boat the constant overheat alarm sounds off after 20 seconds of run time. For peace of mind I replaced t-stats, impeller and pulled the heads just to take a look(all was great). The same thing , ALARM!!! Infared temps on my heads are 128 to 132 with a 142 between the spark plugs and water discharge is 96 to 108. I unplugged the temp switches restarted the motor and no alarm and the power is not held back.
Am I overheating or do I have bad temp switches?
Thanks
P.S. temp did get to 150 before t stats opened.
Thanks
