Bayfisher Dave
- May 30, 2016
- 5
1989 Chris Craft 262 amerosport
Volvo Penta aq271c (chevy 5.7)
Hellos all, I am new here. I have a very Strange problem. I am not new to boats and I am a auto tech. Not master but I'm ok,lol.
Last year late in season, I had to change raw water pump because it took a dump. Clean everything and she ran and pumped well. 4 or 5 trips. Then I got sick and couldn't winterize the boat. It was last used in early August 2015 and always flushed with fresh water. This week I had to replace fuel pump and rebuild the carb (expected). I got the boat running on the muffs and I instantly saw no water coming from out drive lower port. She had only ran for about 2 or 3 mins before I **** her down and went to get new impeller. I removed the old one and instantly was puzzled because it was not even damaged at all! Puzzled I still installed the new impeller and then tried again. No water out rear still. I then disconnected all the hoses. Water runs free back through the tube at rear of motor/bell housing out the out drive water intake ports. Using the hose: water flows from that hose to the raw water pump. The pump does turn with motor and pumps out the port to heat exchanger. I put water hose to that port and water runs out the back of the outdrive. In other words I have no blockages and the pump seems to be pumping cause it wouldn't flow freely through the pump until engine starts. I have never had to prime this system before. I have no leaks while it's running and yet no water out the back so I will overheat. I am at a total loss on this. Plese, please help me out on this. I don't think there is much to overlook in this case. If risers were cracked, they would leak somehow, if they were clogged, I couldn't flow water through them out the rear,right? Please help
