Gene Baker
Thread starter- Joined
- Jan 24, 2009
- 9
Engine has new water pump and I just replaced the thermostat, temperature senser and pressure relief valve. When starting in a barrel the tell tail has excellant flow and initially water flows out the slots in the rear of the exhaust housing. This water is warm and the top of the cylinder head is hot but not too hot. After about 10 minutes the flow out the slots get less and less and then stops and the overheat horn sounds. Any Ideas?
