Overheating 454
Wes Hawkins
Hi Everyone
Its been awhile since I have been on the forum, I got my boat fixed and up and running. I have however taken on a job for a friend who overheated his inboard 454. There was water in the crankcase, water in all the cylinders. He found that the impeller was shot and replaced it after he had overheated it twice. I figured this would be a cut and dry head gasket or cracked head issue but after pulling the heads and having them pressure tested and magnifluxed and finding no warped head surface or cracks I am stumped. I also could find no cracks in the block. There was a lot of water in this engine more in the cylinders than in the crankcase but what should be obvious isn't.
This is an open cooling system unlike that of a car so how do you go about pressure testing a cooling system of this type?
Help please.
Thanks, Wes.
Wes Hawkins
Re: Overheating 454
Thanks guys for tip. I tried this method only using water and saw no leaking anywhere but the acetone makes since. I was going to make set up to pressurize the manifolds but will try this first. The owner now says he not sure how many times he used it after it overheated but now thinks it was a lot more than he originally thought. I did find a suspect spot on the left cylinder head where the gasket looks like it lost its seal. I also found rust staining in the intake manifold in the runners for number 7 and 8 cylinders. It looks like it might well be a blown head gasket and it was pumping water throughout the rest of the engine.
Wes
