I have a 1988 4 Winns Candia with a 4.3 liter V6 OMC Cobra sterndrive. I don't use it much, but it has been well maintained and I have had it for 10 years.<br /><br />The other day the engine overheated. I had been towing a kid on a tube (small, inland Michigan lake) for about 10 minutes when the temp gage went from normal to pegged in a minute or two. I shut it down immediately, and towed it to shore. It is now out of the water.<br /><br />I expected to have to replace the impeller on the stern drive pump, but it is in excellent condition. (I replaced it 3 years ago). What now? What are the steps to minimize cost and tearup of the engine?<br /><br />A friend says the power steering heat exchanger is likely plugged. I would prefer not to tear into it. It is impossible to reach at the back of the motor compartment. Now that the stern drive impeller is out, can I back flush the ps heat exchanger from the hose on the thermostat housing? Would the pressure of a garden hose be too much?<br /><br />We have zebra mussels in our lake. Can you clean out the water intake passage that runs through the outboard unit?<br /><br />The easiest cheapest part to replace is probably the thermostat. Should I have done that first?<br /><br />From what I can read, the next, most drastic step would be to remove and clean the exhaust manifolds.<br /><br />Thank you in advance for any advice. As you can see, I suspect there is a blockage in the cold water intake. Can I test the delivery of cold water to the thermostat housing?<br /><br />Keith, in Michigan
