overheating 130 mercruiser alpha 1
farmergino
I have a 130 mercruiser that I had new impeller installed by a reputable shop a year ago. Has worked great since then. Only used the boat about 30 hours since the work was done. Was at the lake watersking my kids for about 2 hours everything ran fine then all of a sudden it got hot. I shut down and let it cool for an hour started it up and headed for the dock (10 min max) and it got hot again. Could I have gotten something stuck in it? How would i troubleshoot? Can I backflush and if so, how? Unfortunetly the shop that I have used for the last 20 years the owner called it quits and closed his business in January. Any help would be appreciated.
Re: overheating 130 mercruiser alpha 1
Ayuh,... Anything is Possible....
Start by pulling the Lower Unit,+ installing a New Impeller,...
While the unit is Off,... Backflush from the T-Stat Housing to the lower unit...
It could also be the T-Stat,... It's of course in it's housing...
