emoney
Thread starter- Joined
- Jul 19, 2010
- 2,551
Ok, so today was "shakedown cruise day" (it was on the U.S. calender if you didn't see it) and we took the "new to me" boat out. On the way out, after idle speed of about
3/4 of mile (long channel), went WOT, all was well. Had the motor trimmed way too
high and started really porpoising (took me forever to remember that 'down' eliminates porpoising....duh) and all of a sudden it shut off. Hmmm? So, like any good red blooded novice boater, I restarted it and again, WOT, of course with more porpoising. She shut down again. This time I noticed the "key is in the ignition" warning buzzer. Hmm, I didn't know boats came with those. But, I decided to let it sit for a spell. Long story short, after I got my head out of "you-know-what" it dawned on me that the buzzer was the overheat buzzer. We floated for about an hour, turned the key to the first click and there was no buzzer and decided to head back in. On the way back, I finally remembered to trim down, dropped the RPMs to 4000 and she cruised all the way back,
into the channel and up to the ramp with no issue.
So, what do I look for first? There's a steady stream of water coming out the "pee hole"
and the cover didn't feel warm to the touch. This motor was recently worked on, in the carbs, fuel pump, fuel system arena as well as new plugs, timing check etc. There wasn't a new water pump installed, however. Can the water pump be going bad but still have a steady stream of water coming out? Did I bring on part of the issue with the severe porpoising and the WOT? Help a brother out, will you? Oh, and thanks!
