First of all "Great Forum!!!"<br />I have a 1992 60 HP Johnson (sorry no model etc.<br />boat is up north) and I am getting the Overheating solid buzzer warning. On occasion it will cut back on power and shake like crazy S.L.O.W. mode (thx to other posts). The interesting part about this problem is that it is quite intermittent. On occasion it will even "whale" away on initial startup (cold engine). Turn engine off/on again and buzzer will stop. It will even run for a couple of days and then it will return. Sounds as if I might have a wire(frayed = ground) somewhere or possibly a bad temperature sensor.<br />The engine outputs cool water, coolant, and does not appear to run hot as I am able to touch the engine and hold while buzzer is screaming.<br />Any thoughts/suggestions??<br />Also, does this Tan/Blue wire leading from the back of the engine block (temp sensor) lead all the way back to the throttle assembly (where buzzer appears to be located)? I need this information if I am going to trace the wires.<br />Can anyone point me to information on the procedure for replacing the temperature sensor?<br /><br />Thx in advance
