Tommygreeneyez
Thread starter- Joined
- May 29, 2007
- 28
I have an 87 Yamaha 115 115ETLH, and today when I was out on the river I started getting an overheat alarm when I was at full throttle only. I would shut it off and then when I turned it on the alarm was still there but as soon as I increased throttle it went away and stayed away..until I went WOT then it came on after about a minute...It was shootin water out the tell tale same as always..so Im not sure whats wrong...I pull the releif poppet out when I got home and it didnt fall out freely when i removed the spring...but it wasnt jammed in there. as soon as i grabbed it and pulled it came right out..so i dont know if that is the problem..I am assuming the imellor is fune because of the water coming out of the hole strong. Any ideas here..and where are the t-stats on this so i can check those...Im not strong on 2 stroke engines but I work on car engines all the time..so i would assume it was a tstat sticking, but why would the alarm go away and them come back..any help would be appreciated
