overheat alarm
takidd4597
I have a 1988 Mariner. It is a 3 cylinder. I have been getting and alram on my throttle control. It did it one day when I was trimmed down and when I trimmed up it went off. Today while we were out I was having a problem with water in the gas and the entire time the alarm was going off. Could not get on plane until I worked the water out of the carbs and line. The motor was just worked on and they put a new head gasket on.. Supposedly for the same reason. I have a stream of water comming out like a garden hose. I can keep my hand in the stream of water. There is no way this water is over 120 degrees. This is a 60 hp Mariner 1988.<br /><br />I have one wire next to the top cylinder with an very small thin nut. I mean it is very very close to the top spark plug. They told me the impeller was replaced as was a new head gasket.<br /><br />Is there a certain temp the pee water should be to tell if it truekly is overheating?<br /><br />Help please. <br /><br />Can anyone tell me what could be causing this alarm and why and what I can do to fix it?
D
DJ
Guest
Re: overheat alarm
takid,<br /><br />After warmup, touch the top cyliner head with your hand. You should be able to hold it there for a few seconds.<br /><br />You need to find out why that alarm is going off. It's telling you something.
boatingfool
Re: overheat alarm
I havent heard anything about the thermostst.<br /><br />How long is it running before the alarm goes off?<br /><br />If the thermostat isnt opening then the water wont circulate the block so it the water coming out wount be that warm.<br /><br />I would not run that engine again until you narrow it down.<br /><br />I had a similar problem in my engine (temp alarm only) but when I brought the throttle back to idle the alarm would stop.<br />It was the thermostat.
Trent
Re: overheat alarm
Is this oil injected? If so, Is the alarm on all the time or is it beeping? Beeping is oil alarm. On all the time is overheat.
hondon
Re: overheat alarm
You do not have a head gasket on this engine.It would be interesting to know how that dealer justified changing it.
ob
Re: overheat alarm
Trent makes good point.Insure that what you are hearing is in fact the high temp alarm.If you have determined that it is actually a high temp alarm since you mention that it occurs when motor is trimmed it leads me to think that you possibly have a problem in the wiring of the alarm circuit that is affected by the movement or bending of the wire harness.<br />Hondon also touches on a point of interest in regards to the head gasket.
