Tomsawyer1968
- Aug 7, 2016
- 20
Hey guys I'm fairly new to the fiberglass boat restoration scene. I recently purchased a 1968 Tom Sawyer 16 ft runabout. The boat is in decent mechanical shape and runs well. I am a fan of older boats and love the classic lines. However I am researching refinishing ideas for my failed gel coat. I am aware of the many options of paint and gel coat systems but I am having issues deciding which option would be the best. The boat would have to be taken down to bare fiberglass on the top sides and bottom due to crazing, spider cracks, and dings. That in its own right is a daunting task. I am no stranger to hard work and I am more than capable of putting in the time required to get her sanded down. The boat came from the factory with all white gel coat and in the effort to keep things original I'd like it to remain that way. Where I am feeling over whelmed is the death by Google and forums of the many options for accomplishing this task. My major questions fall in the initial step of what to do after the boat is back to bare glass both above and below the water line. Can gel coat be applied directly over bare fiberglass with no primer or sealer between the glass? Is gel coat just a one step process over the bare glass? This would make since due to it being applied first from the factory in the original mold. I understand that a sprayed or rolled gel coat used as a top coat takes a lot of elbow grease to get it worked down and smooth. Due to that reason I have considered paint. But I have issues with longevity when it comes to paint and the difference between bottom paint and top paint. As i said I would like the boat to be all white when completed. Most bottom paints don't appear to be very glossy and I'd like to avoid a boot stripe around the bottom to transition from the bottom paint to the top paint. Also cost becomes a factor with the paint idea due to the various primers and barrier costs needed to seal the bare fiberglass below the water line. Any help setting me down a workable path would be appreciated. I have attached a few pictures of the boat to give a feel of what I am working with. I can include more tomorrow with close ups of the crazing and fails gel coat if needed.
