Saltydog#1
- Aug 24, 2023
- 4
Outfitting Klamath 18 CC with 2017 60HP CT trying to figure where to start on Prop size. Probably aluminum.
Remember it’s a CT gearbox. If it’s anything like the other CT 2.1l mercs (like my 115 version), you’ll need the larger (and better range) type props, for the larger gearbox size.The best info I can find is somewhere about a 13.5 X 16. The Klamath is a light boat 1200 lbs.
Isn't the CT gear box a casting used on the higher HP 75 thru 125 HP Mercs running a 2.33 gear ratio? I have 2 of those and they run a 13+ diameter prop. whereas the 60 with regular gearbox would run a 10+ inch prop?????Remember it’s a CT gearbox. If it’s anything like the other CT 2.1l mercs (like my 115 version), you’ll need the larger (and better range) type props, for the larger gearbox size.
I run a 19” or 20” 3 blade tempest plus or enertia on my 19ft cuddy and 115 ct. 43-45 mph at 6100/6000 rpm roughly
It is. Up to 115hp these days.Isn't the CT gear box a casting used on the higher HP 75 thru 125 HP Mercs running a 2.33 gear ratio? I have 2 of those and they run a 13+ diameter prop. whereas the 60 with regular gearbox would run a 10+ inch prop?????
I ran a 14" dia. Hustler on my 90 Merc for a short period just for grins. I don't remember where I obtained it, not the pitch. Obviously I didn't like it as it didn't stay on but a few minutes and back to the dock to put on something else. Had 1/4" clearance under the AV plate. Had the short trim tab and the pitch wasn't all that much so I cleared that.It is. Up to 115hp these days.
Just thought that a 13x16 would be an odd size for it.
There is certainly a 16x16 that would fit it
Merry Xmas to you too.I ran a 14" dia. Hustler on my 90 Merc for a short period just for grins. I don't remember where I obtained it, not the pitch. Obviously I didn't like it as it didn't stay on but a few minutes and back to the dock to put on something else. Had 1/4" clearance under the AV plate. Had the short trim tab and the pitch wasn't all that much so I cleared that.
I assume that you mean 16" props are probably available in 16P?????
I assume Salty dog had shopped around found a 13x16 and that was why he mentioned it. Thinking about how props increase in diameter as you reduce the pitch, I would think that a 16 if it existed, would be more like 13 3/4" diameter.
Merry Christmas
Cheers Texas. Merry XmasI guess I was somewhat narrow minded on thinking that the CT would only be the next size up gearbox....never thought they might up it a notch and make some engines with the 150+ gear case which would allow for the 14+ diameter wheels .
Your numbers are as you say, quite impressive. Nice chat!
