Outer Head Gasket
rich83
Hi, I have a new cover that goes over the head, where the spark plugs install at. The reason I am replacing mine is because somone used a helicoil, and it is starting to come out.
I am wondering if anyone could give me the correct gasket for it?
Or an item #
Thanks!
maxum247
Re: Outer Head Gasket
I think the part your refering to as the head is actually the cylinder block with the pistons in it and the cover as you mention it is the actual head, the part the sparkplugs screw into.
Give info on the year, horsepower and what type engine you have and I'm sure someone will be able to point you in the right direction!
Good Luck! And have fun on the water!
rich83
Yeah, wasn't for sure if that was called the head on a boat, or if it was a head cover.
Sorry forgot the model 757H8D 1978 75HP chrysler.
Thanks!
