outdrive stuck in forward gear
badluck23
ok, so I pulled the shift mechanism out thinking it was something with that and when i got into it i noticed the gears on the upper drive shaft look good but i can't get the upper gear to slide up to disengage into neutral. I tried to turn the prop by hand hoping it would free up the gear, but I couldn't make a full rotation. I'm thinking the compression in the motor is making it hard to turn, so I plan to pull the spark plugs out to make it easier to turn the prop by hand. I'm also thinking that that upper and lower gear should slide up and down fairly easy or am I wrong in my thinking? What would cause this set of gears to not slide up and down easy? When I drained the lower unit last fall, there weren't any metal filings on the magnetic drain plug.
Idlespeedonly
Re: outdrive stuck in forward gear
What are we working on? If it is a cobra all the shifting is done in the lower unit.
badluck23
yeah it is, in the upper gear case i can't get the upper gear to disengage
badluck23
it is a cone clutch style, just thought i would post a new one putting what my actual problem was trying to get someone else to take a look at it
