billwright43
- Oct 28, 2005
- 10
1985 mercruiser 4.3 with Alpha Gen 1 outdrive. Last time on water easing along no wake speed, didn't hit anything, no bang or jar but boat by itself went into neutral and would not go into either forward or reverse. Luckily a tow came along and I took it. Got boat home cranked on muffs, boat went into and out of forward and reverse as if nothing was ever wrong. OK it sat up a few months and now it's lost impellor flow to the thermostat housing. I rigged a separate flow to the thermostat housing so I could crank the engine and winterize. In doing this, I checked the forward/reverse issue above and now AGAIN it will not go into either gear. Also, outdrive gear oil is seeping out the weep hole. Drained gear oil, no metal or water in oil. Obviously, the outdrive impellor needs attention, but...is the "not going into gear thing" a separate problem or could they be related. Lower shift cable was replaced a year ago, wonder if the mechanic didn't get the lower shift shaft seal installed correctly causing the weep hole leak. Maybe they are all unrelated? What do you guys think?
