Outdrive oil in bilge
89retta
On older merc outdrives is there an oil line running into the motor area from the outdrive ?
GA_Boater
Only if the drive is equipped with a gear lube reservoir tank.
Time to remove the drive and see if the bellows have gear lube from a bad seal in the upper.
achris
More fish than mountain goat
Define 'older'... (20 years old is still the current model)
Let's have engine model, year and serial number and drive serial number....
Chris....
89retta
Sorry guys dont have all the info it's a buddy's boat. As for age late 70s early 80s
wahlejim
Master Chief Petty Officer
In that age range, unless a reservoir was added (unlikely and unnecessary) the only oil lines that go through the hull are for power trim. The only way for gear lube to enter the hull is through the bellow and you have a blown outdrive seal, otherwise you have leaky trim lines, which will happen after 40 years
89retta
He found a seal blown out. Thanks
